03-26-2019 01:40 PM
Dear All,
Greetings!
I am a beginner of Labview and for my project goal, I need to monitor and log real time information of temperature of grains, air, and desiccants. To do this, I bought NI 9149 chassis and NI 9214 and TB 9214 modules. However I am facing problem while configuring NI 9214. I cannot see any option for selecting thermocouple type and measurement temperature unit for each channel (pls see the attached image). I went through the materials (getting started with NI 9214 from C:\Program Files (x86)\National Instruments\LabVIEW 2018\examples\CompactRIO\Module Specific\NI 9214) as suggested by NI forums. However since I am using NI 9149 Ethernet RIO chassis not the compact RIO so I am getting error while running my host VI. The FPGA vi is working fine for measuring TC and CJC output but the host VI is showing errors e.g missing conversion vi (pls see the attached vi’s). I have atatched my FPGA and PC vi fyi.
Hence could anyone please let me know how can I include the necessary sub vi’s for converting NI 9214 data function into my pc vi and whats is the best way to configure my thermocouple (k-type) with NI 9214 to acquire the temperature data at desired unit. Your time and help would be very much appreciated in this regard.
Thanks and regards,
Momin
03-25-2019 07:13 PM
Hello Jeremiah,
Greetings! I am a beginner of Labview and for my project I need to collect real time temperature of grains, air, and desiccants. In this connection we bought NI 9149 chassis and NI 9214 and TB 9214 modules. While going to configuration of the 9214 modules I did not see any option about thermocouple type and measurement temperatures. I went through the materials (getting started with NI 9214 from C:\Program Files (x86)\National Instruments\LabVIEW 2018\examples\CompactRIO\Module Specific\NI 9214) per you suggested. However since I am using NI 9149 which is basically an ethernet RIO chassis not the compact RIO so I am getting error while running my host VI. The FPGA vi is working fine but the host VI is showing errors. I also checked the block diagram of the NI 9214 convert to temperature (Calibrated) function but I cannot able to open the embedded cRIO convert thermocouple reading. vi and getting error. Hence could you please let me know how can I configure my thermocouple (k-type) with NI 9214 to acquire the temperature data.
Thanking you and looking forward to hear you.
Momin
03-26-2019 11:25 AM
Hi Sumon_Davis,
Since this is an older post, I would recommend starting a new thread for your question. When you do, you can add more information about the errors you're getting, and other forum users will be able to better assist you.
03-26-2019 01:28 PM
Hi Melanie,
Thank you for your reply and your suggestion. I will do it asap.
Momin
University of California Davis
03-27-2019 08:48 AM
Hi Momin,
Can you attach screenshots of the errors you're getting?
03-27-2019 12:53 PM
Hi Melanie,
Thank you for your reply. Let me share you every steps I followed with updated vi's. My FPGA vi working fine but when I tried to open the PC vi it was asking, to select a file and I selected calibrated conversion vi (pls see the images of PC_vi_1 to 4). Then I was able to open PC vi but getting errors as attached. I also attached the final window of project explorer and the updated vi's fyi. I think I am missing something to reach out there. I will very much appreciate your time and help. Sorry for lot of attachments.
Looking forward to hear from you.
Momin
04-08-2019 12:58 PM
Hi Melanie,
You know fortunately I found this doc in the shared folder of the National Instrument and I did the same and was able to solve the issue by dragging all supporting VIs into my system. But you know while saving it creates a long file path C:\Users\Desktop\Momin_LV_2\examples\CompactRIO\Module Specific\NI 9214\NI 9214 Getting Started However its working fine except I need to change the thermocouple type (from J to K) every time I run the VI. I am not sure I am doing right or not, but I believe you may figure out a robust way to solve the issue.
Thanking you again.
Momin
04-08-2019 01:16 PM - edited 04-08-2019 01:19 PM
Hi Momin,
But you know while saving it creates a long file path…
I usually place all my LabVIEW projects in a folder like D:\Data\LV_2018\project.
No need to add 4 or 5 more levels of folders!
04-18-2019 11:42 AM
Hello GerdW,
Thank you for your suggestions. I set the k type as new default value and it is working now.
Momin
