01-17-2014 12:04 PM
All,
I am working with an older SCC system with the following modules:
2@AI03
3@TC02
2@SG24
1@AI05
The orginal VI for this system used DAQ Assistant to configure each module individually, with different signal input range, scaled units, terminal configuration and custom scaling. See attached photos.
I am writing new code, but I don't generally use DAQ Assistant. Is there a way to configure each module individually without use DAQ Assistant? I have tried to configure the different modules directly, but I get "Resource not available" errors when I try to run the code.
Or should I just bit the bullet and use DAQ Assistant?
Thanks for any help.
Solved! Go to Solution.
01-17-2014 12:42 PM
01-17-2014 12:46 PM
Ah! So I just daisy-chain multiple "DAQmx Create Virtual Channel" icons together, then start them all at once, yes?
Thanks!
01-17-2014 01:22 PM
Since they are daisy chained, they will execute one after another but the task with all channels will start when you command it to.
01-17-2014 01:40 PM
