Configuring CAN channel properties through MAX
Hello all,
I am new to CAN configuration through MAX. I want to do the following in my application:
I want to have a CAN message with D900 PGN (Mem Access Request). In this the Destination Address(DA) would always be changing. So for eg, we have DA=24, the Mem access request message should become D924. Now, I want to dynamically create a task which would be deployed on RT for sending this message after every 100ms. The remaining field (Priority and Source Address(SA)) remains the same. However, the pointer in the 8 byte data field will also  change dynamically.
Could anyone help me in creating and configuring these channels in MAX so that I can deploy them to RT? (I am using PXI CAN)
-FraggerFox!
Certified LabVIEW Architect, Certified TestStand Developer
"What you think today is what you live tomorrow"
Message 1 of 1
(2,496 Views)
