Brian Vibert wrote:
> Maybe I'm missing something, but I thought that LLBs were only able to
> store VIs and CTLs. If you want to prevent the users from changing
> them you could hide them somewhere else. The other thing that you
> could do write a routine to encrypt/decrypt the file.
> Brian
Hi Brian,
LLBs can store anything and keep files together in a easy way. For
instance, if you create a Run-Time-Menu for a VI, the aprobiate file
"Menu.rtm" is written into the LLB where the VI is in. I just figured,
that not all file I/O VIs can handle LLBs.
You can check this by starting Tools>VI-Library-Manager from the control
panel.
Ciao,
Rainer
