05-09-2006 09:45 PM
05-10-2006 01:48 AM
Hi Rob
You probably want to use a shift-register to remember the last state that your cluster was in. You can use the Bundle function to modify the elements of your cluster. When you need to manipulate array elements I would read the array from the shift-register using the unbundle function then update the array elements before bundling them back into the original cluster
You didn't mention which LV version you are using so here is an example in 7.0.
Hope this helps you out.
David
05-10-2006 11:45 AM
For the record I'm using labview 8.0 and despite the example I still can't break up the structure that condor created for their API.
Rob
05-10-2006 12:27 PM - edited 05-10-2006 12:27 PM
It really should be a simple task with the Bundle by Name function. What don't you post your code or a picture of what you are doing.
Message Edited by Dennis Knutson on 05-10-2006 11:28 AM
05-10-2006 12:56 PM
