Concatenate arrays
Hi ,
I am detecting Peaks in XY graphs. I get all the information regarding the peak detected ( like start X, start Y, summit X,  summit Y etc ) in an array. Each time a new peak is detected , the information of previous peak (which is in an array ) gets deleted and information of newly detected peak is filled. Now, i want to retain the information of all the previously detected peak, when the information of newly detected peak is filled. It might be very simple, but i could not figure it out how to concanate the information of previously detected peaks with that of newly detected peak. Sample VI would help me better...
Nilesh
(2,756 Views)
Have a look at shift registers. 😉
(2,741 Views)
@Nileshv wrote:
Hi ,
Nilesh
I assume your code is sitting inside a while loop polling for Peaks.
Then, you ve to use Shift Registers to hold back the values obtained during the previous peak and pass it to the Concatenate function.
Rt click on the border of the while loop & Add Shift Register option will get you started to do what you wish to... Smiley Wink
- Partha ( CLD until Oct 2024 🙂 )
(2,739 Views)
Altenbach,
You ve just beateb me in the blink of the Sun's eye ! Smiley Wink
I mean the Sun's rays approx take 8 min to reach the earth. Smiley Very Happy
(2,736 Views)
Here's an example that shows the use of a shift register.
(2,729 Views)
