03-17-2010 03:37 AM
I wan to learn concatenate jpeg files. I wrote some code about this but my solution is not good solution to concatenate jpeg file.My code only can show my jpeg files step by step. Firstly this code can show first jpeg after second jpeg so on... This code is a kind of concatenate jpeg files but I want to see all jpeg files same time with sameviewer.
Actually i want to do adding 5 or more jpeg files (same size 600x600) and then i want to see all jpeg files with use slider on the jpeg viewer.Which is the best solution to do this?
Best Regards
Kadir Can AYHAN
Comp. Eng. /Turkey
new user for LABVIEW
Not: this code created by labview 09 and you must open same directory with jpegs files. Your jpeg files must be same pixel size For ex: 600x600(I send it)
Solved! Go to Solution.
03-17-2010 04:32 AM
03-17-2010 06:51 AM
03-17-2010 10:48 AM
SrikrishnaNF, hi again
your code is very good solution i tried it and work but can u explain this: if i have 5 jpeg files in my file directory (it has 5 jpegs file), your code ask other jpegs files how can i solve this problem?
Actually i sent to jpeg about my problems you can see if u want
thank u for everything
03-17-2010 11:13 PM
hi kacco,
The reason for your problem is may be slider.In your program the if the slider is showing more value than actual number of files,obviously it will end up with an error.So please make sure that the marker values on the slider should not exceed the actual number of files in the selected directory.If possible ,please place a digital display for your slider also and verify the values of the slider.
Thanks and regards,
srikrishnaNF
03-18-2010 06:16 AM
thank u,
your point is right ad i solved thank you with your helps and ideas....
Do u have any idea about image processing since i am new image processing with labview.I want to help about this subject if it is possible? Now i am solving my problems but if ı didnt, i can send a e-mail or call
This is my e-mail add: kaccoayhan@gmail.com you can send e blank mail if you want...
Thank you again...
03-18-2010 07:21 AM
03-18-2010 07:22 AM - edited 03-18-2010 07:22 AM
