Concatenate 2 numbers of a 1darray
Hello everyone,
one question from a LabView noob!
I want to concatenate 2 numbers from an 1darray to one number.
For example [123,456] to [123456].
In my Vi this can be solved for small numbers, but it s not working when the numbers get to big. What am I doing wrong? 😄
Thanks for any help!
Cheers,
Jay
Message 1 of 13
(5,509 Views)
Your datatype is a U8 which means it can only have the values between 0 and 255.
Try U32 instead!
PS:  You don't need the constants 0 and 1 wired to the indices of your Index Array function.  It will give those indices by default when unwired.
Message 2 of 13
(5,507 Views)
The biggest problem with your Picture (please, attach executable code, like a VI) is that you are trying to cram a 6-digit number (123456) into a u8, which is at most 3 (decimal) digits, e.g. 256.
If you had looked at the intermediate string, you might have seen "123456" and might have realized "Oops, how do I express this as a U8?".  Do you know how to force the Scan from String function to output a U32 (or an I32)?
Message 3 of 13
(5,501 Views)
There are also function under the Numerics >>> Data Manipulation palette that are useful.
Join numbers
Swap Byte
Swap word
Type Cast
You should play with those a bit. Like Radigas said "You have to fiddle with it a bit."
Have fun!
Ben
Message 4 of 13
(5,495 Views)
Thank you everyone for your quick response!
It is working when I am unsing U32 instead of U8!
Bob_Schor actually I don t know hot to force the funtion..how is this gonna work?
Another question: When I am using hexadecimal numbers it doesnt work, for example:
I have the numbers [47,31] convert them into hex[2F, 1F]  and get [127B] with the VI. 127B converted into decimal is 4731.
How can I get 2F1F, which is 12063?
I hope my question is clear!
Thanks again!
Jay
Message 5 of 13
(5,466 Views)
Accepted by J_Print
Convert them to hex strings.  %x.   Or you might need %2x if you want to ensure that numbers less than 16 have 2 characters.   ("0A" for 10 instead of just "A").
To force a datatype when converting from string to integer, wire a constant to the dot at the lower left of the Scan from String Function.  Assign it whatever datatype you want such as right clicking on it and picking Representation >> U32.
Message 6 of 13
(5,454 Views)
For that task you can use the already mentioned "Join Numbers" primitive:
Or if you want to convert your complete array with 1 function use "Type Cast":
Regards, Jens
Kudos are welcome...
Message 7 of 13
(5,443 Views)
Put down a Scan from String function.  Right-click it, choose "Help", and read the Detailed Help.  Look at the explanation for the lowest left input terminal -- it defines the Type and Default Value of the corresponding output.  So if you wire the default I32 Numeric (from the Numeric Palette), you'd get an I32 out.  What if you want an I16, or a Sgl?  Right-click the numeric you have wired, and change its Representation to whatever you want.
Message 8 of 13
(5,439 Views)
Hello guys,
I still have a small problem with my evaluation.
Numbers that are less than 16 are not correctly output. I took the advice from RavensFan and replaced %x with %2x, but it still don t work.
The concatenation of the two numbers fails. The numbers for example [2F, B] are transformed into 2FB (when %x is used) and 2F B (when %2x is used). The correct form would be 2F0B.
Where is my mistake?
Thanks for any help! Smiley Happy
Cheers
Jay
Message 9 of 13
(5,375 Views)
Accepted by J_Print
@J_Print wrote:
Hello guys,
Cheers
Jay
You are over thinking the problem. Way too many conversions to get from U8 to U16. Here is a simpler way (oops! JensG69 already provided this solution)
Message 10 of 13
(5,370 Views)
