Compiling
I am running LabVIEW 8.6.1.  When I compile the program, I can generate a list of dependencies showing all of the sub-VIs in my program.  Great.
Is there any way to export that list to a Word doc or an Excel file so that I can include it in a manual that I am sending to my client as part of the source code?
(2,237 Views)
Yes. (Edit: I wrote this using 2017. Reading back after posting, I don't know that this functionality (all, some, none) is available in 8.6.1...)
You can get a (programmatic) list of Dependencies using VI Scripting:
Here I'm outputting a cluster containing the Name and Type of the item. Be aware that this won't expand items (folders, libraries etc) so you can check the type and then use a case structure to handle it in a shared-clone reentrant subVI.
You can also get "All VIs in Memory", but this won't list other parts of your dependencies that are loaded indirectly (I think). So you have to be careful - this might do what you want but only if you're actually using all of your dependencies in your project (again, I think).
Once you have a list you're happy with, you can use the Report Generation Toolkit to create a Word or Excel file.
GCentral
(2,207 Views)
Or simply save to a text file, and open it in word\excel. If you call it .csv, IIRC Excel is associated with it. RGT is a huge dependency to add...
(2,188 Views)
Definitely my preference too if there's no specific need for a "real" Word or Excel file.
GCentral
(2,162 Views)
Thanks very much.  I will see if I can do this in 8.6.1
(2,149 Views)
I believe that scripting was implemented but it was not exposed in LV 8.6
The rest of should work.
Alternatively a "Source Distribution >>> Preserve Hiarchy" to a clean folder and then listing the folder contents can get you there.
Ben
(2,142 Views)
