Compiled application appears off-center in window when it runs.
Dear Support Folk,
    My compiled Labview application appears off-center in the window of the target machine it runs on.  There are scroll bars to adjust the display, but it does not look professional.  I can control the executable's appearance in a hit-and-miss fashion by manipulating the placement on the host computer just prior to compilation.  What is the right way to do this?
    Thanks!
    Herb.
(3,107 Views)
Go into File>>VI Properties>>Window Appearance and select Customize.
Also, you can use a property node to set the front panel state to maximized.
___________________
Try to take over the world!
(3,107 Views)
Dear Lucky,
Thanks -- It looks good...
Herb.
(3,100 Views)
