Compatability Issues With Latest Version of DAQmx
This one has got me stumped, so I thought I would go to the message boards.
I am running some equipment that returns a voltage thru a NI USB-6361. The company that has hired me was using an older version of LabView (I cannot tell you which one, 2012 I think). Further, they are using DAQmx 9.5.5, which came with the USB-6361. My problem is getting my computer to A)recongnize the USB and B)still keep all my DAQmx VI Icons when I am programming. If I roll back the DAQmx software ti 9.5.5, I lose my Icons, but if I stay with DAQmx 9.9 I can see the USB in MAX, but that is it. In MAX I cannot create a task or anything. It shows it as "Not present"  I am using LabView 2013, and I have done everything I can think of. Has anyone had this problem? How do I fix it. I thought DAQmx 9.9 was supposed to be compatable with this device. Thanks in advance for the help.
(2,873 Views)
Accepted by mech_eng_87
Have a look at this:
Compatibility LabVIEW & DAQmx
If you are using LabVIEW 2013 then you need to have at least DAQmx 9.7.5.
Regards, Jens
EDIT: And yes, DAQmx 9.9 should be compatible with your USB 6361
Kudos are welcome...
(2,868 Views)
Well that explains it. I guess I need to figure out why I cannot access the USB 6361. Thanks for the help.
(2,837 Views)
