12-04-2007 09:10 AM
When comparing the aggregates of an array, the Greater? function comparesBottom line: for what is being done in the original example, aggregate compare mode should not be used, though the poster has already figured that out.
each element individually starting at index 0 until it finds the first set of
elements that are not equal. The comparison of these two elements yields
the result. Notice how the comparison of the first y value(s) in this graph
determines the value of the boolean indicator.
12-04-2007 09:19 AM - edited 12-04-2007 09:22 AM
12-04-2007 09:24 AM
I'll try to return to this Q latter today.
There is an explanation for this behaviour that simply will not come to mind at the moment. ![]()
For the time being, I concider this mor a bug in my memory than in LV. ![]()
Ben
12-04-2007 09:29 AM
smercurio made it clear... thanks.
allthough i don't like it....
12-04-2007 10:06 AM
FWIW, it strikes me as puzzling and arbitrary that "the first unequal elements" get to dominate the aggregate result. I think a case could be made for an implied logical-OR of the element results and an even better case could be made for an implied logical-AND. But to make the aggregate result potentially depend on the SEQUENCE of the elements?!? Weird...
(I know "bug" is a touchy word. If the node behaves as designed/documented, it won't be considered a "bug." But what a weird design, IMHO.)
-Kevin P.
12-04-2007 10:06 AM
12-05-2007 07:32 AM
09-16-2015 05:53 PM
I'd like to get community input on submitting this as a bug. The current behavior is not only undocumented:
It is also wholly at odds with the intuition of everyone I've presented to. Please see the attached .vi, whose behavior I find immensely confusing.
I get that the function is comparing aggregates rather than aggregating comparisons, and I get that aggregates of an array might be compared using the "phone book" method, but unless the documentation is updated to reflect current behavior this will be a recurring problem. Addition of an "aggregate comparisons" mode would help clarify. Maybe an "OR all comparisons" and an "AND all comparisons".
09-17-2015 01:03 AM
If you click the second link in that help article, you should find (among many other things) the following paragraph:
Compare Aggregates Mode
In Compare Aggregates mode, comparison functions return a single Boolean result after comparing the elements in an array. Comparison functions compare elements sequentially until a decision can be made, much like the alphabetical ordering of English words, where letters of each word are compared until they are not equal. Therefore, the function performs the following steps to determine the result of the comparison:
- The function compares corresponding elements in each input array, starting at the beginning of the array.
- If the corresponding elements are not equal, the function stops—it returns the result of this comparison.
- If the corresponding elements are equal, the Comparison function processes the next pair of values, until it finds an inequality or reaches the end of one of the input arrays.
- If all values in the input arrays are equal but one array has extra elements at the end, the longer array is considered greater than the shorter one. For example, a Comparison function considers the array [1,2,3,2] to be greater than the array [1,2,3].
There's a similar paragraph for clusters. I don't know if that's the best place to put it (maybe there should be at least a note in your screenshot), but it is in the documentation.
As for which is better, I have no particular opinion. My intuition was also that compare aggregates simply means "AND everything" (which it does, if you're equating) and I was confused when I first ran into an inequality which didn't behave that way, but I use this rarely enough that I don't have a strong opinion.
