04-11-2011 11:49 AM
I am currently working on a Compact RIO and would like to deploy the VI as a standalone application to run independantly on the Compact RIO without the need for a host computer. Apart from that, the Compact RIO also has to have internet access. I have a CRIO 9022 and am unsure how to set up internet access for it as well. Should the Ethernet cable be plugged into Socket 1 or Socket 2? The other end of the ethernet cable is connected to a switch with internet access enabled.
Please Help
04-12-2011 04:55 AM
If you're looking for the cRIO to sit just on an ethernet port with internet access then I'd recommend using Ethernet Port 1 either with DHCP or a static IP that isn't in use by your network.
04-12-2011 05:39 AM
Hi
Thanks for your reply. After we set up the Compact RIO to run st startup with a real time application, what other settings do we have to configure to allow it to have internet access? The IP address is static. Also, we would like to have a remote front panel service running in order to view the front panel from a remote browser to monitor our system. Would it be possible to provide me with some step by step instructions of setting this up? I tried the steps from the guides at National Instruments website but all of them require the presence of a host computer, whereas we are building a real time application.
