03-05-2007 03:02 AM
03-05-2007 04:40 AM
Nicely done, Ben.
@TonP wrote:
Using 1$s allows me to reuse the first input twice
Unfortunately, this only seems to work in recent versions.
03-05-2007 06:24 AM
03-05-2007 06:41 AM
03-05-2007 07:32 AM
Wow, so many good replies so little time.
Scott,
Thank you sharing the details of your fix. That is an elegant solution to having the best of both worlds.
Guenter, Pinc, and Shane,
I think you are telling me that you start to define you data structures before wiring! I was hoping that I was not alone in that step. It helps me define the functionality of my "fuzzy clouds" and how they interact. The dynamic update of type def's let's me move boyond that phase without having to worry about if I missed anything.
Ton,
Nice example of cross application type definitions! I find the customized icons allow my thoughts to focus on the work being done rather than "how is it being done".
Re: Type def update bug
LV had this problem prior to LV 7.1. I concidered it amoung the worst type of bug since it was "silent but deadly." I have not seen it since LV 7.1. If you have seen this issue since LV 7.1, PLEASE POSTY AN EXAMPLE so we can get this fixed.
Thank you all for bumping this Nugget up a notch with your replies!
Ben
03-05-2007 07:52 AM
Ben,
Thank you for a great nugget. I think I have climbed up a notch on the LV food chain with the knowledge that you have given.
Woderful post.
03-05-2007 10:03 AM
Very well done Ben!
I will need to explore this very shortly with a new project!
RayR
03-05-2007 10:25 AM - edited 03-05-2007 10:25 AM
Joe and Ray,
I look at is a "boot-straping" the LV community to a higher level.
Here is an example that clearly illustrates the benefits of wrapping the type def's in a sub-VI.
The type def that was wrapped up is nice and neat. Meanwhile the cluster constant I did not wrap-up EXPLODED!
Ben
Message Edited by Ben on 03-05-2007 10:25 AM
03-05-2007 11:35 AM
Thanks Ben,
You gave me an ideas for my project.
RayR
03-05-2007 11:45 PM
Hi Ben,
Excellent post, Sir.
You re really not only the master of SD ( State Diagrams ), but TD ( Type Defs ) too.
Where is CC ?! Is he in hibernation ?! U Cute Cocoon, come out please...
I'm thinking that U re in the pipeline for the next nugget.
