Community Nugget 4/08/2007 Action Engines
Well for (1) he was a new developer doing his first project in the LabVIEW team as far as I heard, and for (2) I run into this when trying out the Feedback nodes and at one of the next NI weeks this story was told by people who should know.
Rolf Kalbermatter  My Blog
Message 111 of 161
(2,405 Views)
It seems to me that the functional difference between LVOOP as it is and the AE approach would basically be eliminated if LV offered OOP in a by reference form. Granted, how one would distinguish between a by reference and by value object eludes me. However, AEs are conceptually easier than passing around an object in a DVR or copies of an object containing a bunch of DVRs.
Until OOP makes by reference objects easier, AEs will stick around to fill a niche which many programmers expect to be readily available.
Message 112 of 161
(2,403 Views)
Creating by Reference OOP in LabVIEW is pretty trivial. Just place a DVR in the private data of the object and put the actual data into the DVR. et voilá!
Message 113 of 161
(2,392 Views)
Until you need to find all AE that use a certain function. ("Where's the init?").
That's just one of the reasons I don't use AE anymore. Of course, an AE can (and should, AFAIC) be wrapped in a library, made private, and only the function wrapper should be used to prevent this. At least then I can easily find all init instances.
Still, the AE is a global. And a singleton. That's my next problem. An AE that suits my needs, cannot be reused in the same project. Unless a copy is made, or the AE needs to be redesigned to use some sort of indexing. Both are no good for me... And to anticipate the expected response: yes, this happens to me a lot.
By reference is not the same as being global. By reference you can still follow the wire to see where it's used. And the needed wire prevents random lazy usage of the AE. I've seen that a lot. There is an AE, so it's used everywhere, from the top level to the deepest catacombs of the application. When a wire is required, people are less inclined to do this, and when they do, at least you can follow the wire. Using AE's like this prevents reuse of modules, as there is such a strong coupling between the module and the AE. Obviously, this can be prevented by actually thinking about how the AE should be used, but it's not enforced. And any code that uses by reference objects can still be called twice without problems.
Another side effect of the AE being used throughout the entire code, is that it prevents copying. As the AE are global, cloning\copying anything that contains an AE will make the two processes communicate. Often that's not desired.
That might be true (arguably), but normal by wire objects are even easier.Smiley Very Happy
By reference objects are not the substitute of AEs. By wire objects are.
I never use DVR objects, because they are so terrible to debug. I want to stop my main, and then run a sub VI with the data that it used the last time it run. There's hardly any use for them. I did use them because I though it would prevent memory copies. But then the by wire child performed almost the same without all the disadvantages (memory leaks, debugging). Sometimes there's still need for them, but I manage avoid them most of the times.
To me AEs lean more towards the quick and dirty side of the spectrum. That doesn't invalidate them. They're just not suited for my needs. I can imagine projects where they fit perfectly. I used to make them myself. If you only get those kinds of projects (, and when you don't mind rewriting code when you need an up scale), AEs work wonders. For me, it's the other way around. I work on large projects, where everything is dynamic. So my entire codebase has no AE. So even for smaller projects, I reuse my codebase and experience based on larger projects. So no AE for me...
Message 114 of 161
(2,357 Views)
wiebe@CARYA
...To me AEs lean more towards the quick and dirty side of the spectrum. That doesn't invalidate them. They're just not suited for my needs. I can imagine projects where they fit perfectly. I used to make them myself. If you only get those kinds of projects (, and when you don't mind rewriting code when you need an up scale), AEs work wonders. For me, it's the other way around. I work on large projects, where everything is dynamic. So my entire codebase has no AE. So even for smaller projects, I reuse my codebase and experience based on larger projects. So no AE for me...
As I wrote in that blog linked above, wrapping up the dirty AEs and putting them in a library takes care of many of the issues you enumerated Wiebe. You also confirmed my previous point that if your project is going on for an extended period of time, LVOOP is worth the initial investment of time plus learning curve.
Thanks!
Ben
Message 115 of 161
(2,341 Views)
This is a great discussion and I'm glad I resurrected this thread! Smiley Very Happy
However, I'm still wondering what the best strategy is for a dynamically updating GUI. I have been working on an AE based on Ben's GUI Control, but I'm not sure that's the best option.
My preference would be to go AF and make a GUI actor but I don't have time for that on this project.
Message 116 of 161
(2,327 Views)
You mean the values? Or the layout?
I usually initialize a class (set values) with control references. Then use methods to update the values (and other stuff, like enabling\disabling).
Haven't worked with those QControls jet, but they might make life easier...
Message 117 of 161
(2,311 Views)
Yeah, that's basically what G# does for you, plus you'll get garbage collection, automatic icons and a debugger that'll look at live objects. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 118 of 161
(2,309 Views)
You really need to elaborate more on what you mean by this.  If you are just talking about a single VI's GUI, then I prefer using User Events to send that data/messages to the GUI loop (which should just be a While Loop with an Event Structure anyways).
Message 119 of 161
(2,293 Views)
@crossrulz
My GUI is on the front panel of my main VI, but GUI values are updated by sub-VIs.
This particular GUI will only have indicators, not controls (all controls have already been implemented).
If I understand correctly, you're proposing an event structure in a parallel thread?
Message 120 of 161
(2,286 Views)
