Communication with serial device
Accepted by topic author Gregory
@mcduff wrote:
I know this is heresy, and I will be scolded and yelled at, but may I suggest the using the Bytes at Port.
I am the first to criticize the Bytes At Port.  But I was running a something similar in my head last nigh when I was thinking about this.  As you said, you have to do weird things when a good protocol is not used by the instrument.  Luckily in this situation there actually is a termination character so we don't need to dive through these hoops.
Message 11 of 12
(972 Views)
Thanks all.
I've marked mcduff's solution because it does answer my original question about what to do when there is no termination character.
I've marked crossrulz solution because it looks like ">" will work as my termination character.
Message 12 of 12
(959 Views)
