Communication between Panasonic A6 servo driver and Labview
I am trying to control the Panasonic Minas A6 MCDLT35SF servo driver using Labview. I am using the motor from FUYU. Does any have done this type of communication before? Thank you.
(3,388 Views)
Hi Dibya,
that servo driver allows for several types in IO communication.
Which one do you want to use? Did you read the manual?
(3,336 Views)
Thank you GredW for the reply and sorry for responding it late. I want to send the external pulse to the driver using the LabView, maybe in this case we can use pin 34 35( servo ready). I want to control the position and speed of the traverse by using this external pulse. I am new in servo motor and labview, so i am having difficulty while working on this one. Do you have any LabView code which can communicate with the servo driver and manipulate position, velocity or acceleration?
Dibya
(3,318 Views)
Could you give us the complete picture? what hardware do you plan to use to interface LabVIEW with the drive?
(3,306 Views)
