Communicating with Kikusui PFX 40W-08 via GPIB
I'm trying to work with a discontinued Kikusui PFX 40W-08 and have a GPIB-USB-HS. This is my first time working with LabView and GPIB, so I don't have much knowledge about either. I'd like to use LabView to run some charge/discharge tests, but there is no driver specifically for this product. I have NI 488.2 downloaded but can't get it to work with the tester either. There is a PWX Series instrument driver that I was able to download, but I do not know if I can use it with the PFX.
Any suggestions/resources are welcome, thanks.
(656 Views)
Seeing how I do not have the manual for this instrument.
Does the instrument show in NI-Max?
> If it does:
  • It might support SCPI
    1. Click on the instrument under Devices and Interfaces
    2. Click over to the Input/Output tab
    3. Enter *IDN?\n and Click Query
    4. Does a valid response occur?
  • It might support a version prior to SCPI or a custom command version
    1. Same
    2. Same
    3. Enter ID?\n or *IDN\n
    4. Same
> If it does not, it may either be a different setup like Modbus or it may be using the initial IEEE-488 communications.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(635 Views)
Here is a manual and chapter 5-3 describes the GPIB interface. Definitely NOT SCPI! The identification query seems to be "IDN ?". Notice the space before the question mark.
Rolf Kalbermatter  My Blog
(608 Views)
