Communicate with Mitsubishi Q series by using ethernet for Labview 2009. (Labview 2009 與三菱PLC Q 系列以ethernet 溝通)
Hello, everyone,
I'm brand new in Labview.
Recently, I'm trying using Mitsubishi PLC Q series to communicate with Labview 2009 OPC via ethernet. Everything is going fine to send boolean bit and word to Labview, but is fail to send back word to Labview string indicator. Is there any idea what's going wrong?
Thanks in advanced.
Richard
各位大大,我以 Labview 2009 OPC 與 三菱PLC Q 系列以 ethernet 通訊時,Labview 所送至PLC 的 boolean Bit, word,PLC 都有接到;但是 PLC 欲送至 Labview 的 word 以 string indicator 接收時一直無法成功,其他的 boolean bit 以 LED 接收也都成功了;請問可有成功例子?
(4,043 Views)
device type 選錯了
(4,017 Views)
