Combining Analog Input Data from two PXI-4472 cards...
... but I can synchronize the two boards no problem.
The problem is that I'd like to use only one DAQmx_read.vi and therefore I need to combine the two "task/channel in" inputs from the synchronization subroutine into one.
I've tried array concatenation using BuildArray.vi which gives me type mismatch errors. And I've tried indexing the tunnel into the DAQmx_read.vi loop, but the channel data becomes mixed.
Any ideas?
Thanks a lot,
LLB
(1,617 Views)
LLB,
DAQmx tasks cannot span more than one device. If you just want to use the same VI, I'm pretty sure that you can build a 1-D array of the tasks and autoindex the array with a FOR loop that has the DAQmx Read VI.
Hope this helps.
Erin
(1,617 Views)
