Color matching for ring patteren
Hi friends
I need to match the color of ring type of led and need to consider result
Give me your suggestion to achieve this
LED images attached
(2,008 Views)
Hi kps,
how and where do you need to match the color of those rings in your images?
Which result do you need to consider?
(1,975 Views)
Hi sir.    Thanks for reply ....I am working in one testing machine.This led color verification is one of the functional test present.Need to switch on the led through modbus communication, capture image through bastler camera , Check the current led color is matching with our master image or not
(1,940 Views)
Hi kps,
So there are three clearly defined steps in your approach!
Which of them is giving problems? What have you tried so far? Where are you stuck?
I think the color testing might be easier to implement than the two steps before that. As I'm not experienced in IMAQ problems I guess I would compare the colors using the HSV values of the pixels
(1,926 Views)
Hi sir
I am able to switch on LED, and image also captured,
I am new for image processing i am trying to do color testing(in this step only i am struck)
(1,908 Views)
Refer to this video for color recognition using imaqdx in labview
https://www.youtube.com/watch?v=ef5YGgfjt5Q
CLD Using LabVIEW since 2013
(1,904 Views)
Accepted by topic author kps001
You can try this example code from NI:
https://forums.ni.com/t5/Example-Code/Robust-Color-Recognition-using-IMAQ/ta-p/3519634
(1,889 Views)
