Look at the in range and coerce function on the comparison palette. It outputs a boolean which would drive a case structure. If the action for out of range high and out of range low need to be different, you could do a couple of comparisons to see if the value exceeds the max or is below the minimum and act according in a case structure inside of the True case of the first case structure.
