Code for vending machine
Highlighted
Sir,
     I would like know the code for a vending machine which has x no of items and accepts any change and at the same time returns the excess change back to the customer.
           Thanking sir.
Message 1 of 21
(4,987 Views)
Highlighted
Accepted by topic author vendingmachine
State Machine.
Are you looking for somebody to just do this for you?  Or are you just stuck somewhere?  What have you tried?
GCentral
Message 2 of 21
(4,981 Views)
Highlighted
if code is readily available i will go through it and try it
@crossrulz wrote:
State Machine.
Message 3 of 21
(4,976 Views)
Highlighted
i tried a vending machine which does not give change and acpets only the exact chnge so i would like to modify it if someone guides me
Message 4 of 21
(4,973 Views)
Highlighted
It doesn't seem like your problem is really solved.  So you might want to unmark my earlier post as the solution and give me a Kudos instead.
Care to share your code?  Tell us where you are stuck.
GCentral
Message 5 of 21
(4,964 Views)
Highlighted
Are you doing this as practice for the CLD? If so you may want to spend time figuring it out on your own since there will not be anyone who can assist on the exam itself.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 6 of 21
(4,959 Views)
Highlighted
could kindly assist me with the code
Message 7 of 21
(4,949 Views)
Highlighted
no am not preparing for cld am at the basic level trying to learn labview
Message 8 of 21
(4,947 Views)
Highlighted
You need to show us some code so we know where you are at.
GCentral
Message 9 of 21
(4,935 Views)
Highlighted
If you understand the existing code, it should be trivial to make these changes. Do you understand the code you currently have?
If you show us the original code, maybe we can give you some pointers.
LabVIEW Champion. It all comes together in GCentral GCentral
What does "Engineering Redefined" mean??
Message 10 of 21
(4,935 Views)
