Code based on which relay block in labview is coded
Hi
Can I get the code with which 'Relay' block in labview has been written? I want to use the code to design a similar block in multisim.
Awaiting Reply
Thanks in advance
Ganga
(4,330 Views)
Jim
(4,310 Views)
Hi.
Thank you for the quick response,  and apologies for the absurdity in asking my question.
I meant code in terms of pspice(which can be used in multisim) and not labview code.
Awaiting reply.
Thank you.
Ganga
(4,271 Views)
it might be helpful to post your subject here
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
(4,263 Views)
There is no spice code associated with any LabVIEW code so your question is completely misplaced. Post to the Circuit Design Suite for questions related to Multisim and provide details on the hardware you need a spice model for.
(4,260 Views)
Thank you for your quick response. I'l post this question underv circuit design suite Thanks
(4,205 Views)
(4,204 Views)
