‎05-01-2008 07:47 AM
‎05-01-2008 08:10 AM
‎05-01-2008 08:14 AM
I forgot to mention one thing.
You simply have to be careful not to open a VI created by an older version with a newer version of LV because it will save it in the newer version. Unless yo do want to bring up the version of the vi.
In other words, if you have a VI created in LV 7.0 and you have multiple versions installed; then you wish to open the LV7.0 vi but keep it as a LV7.0 vi; right click and use Open With and select LV7.0. You can open it with any newer version as long as you do not save it because it will save it to that newer version. However, opening it with LV7.0 and saving it will preserve it to LV7.0.
Other suggestion: keep a backup copy of your work 😉
RayR
‎05-01-2008 08:26 AM
‎05-01-2008 08:58 AM
‎05-01-2008 09:15 AM
Good catch tst.
It's been so long since I've used Win 98 that I missed that one. Thanks 🙂
‎10-07-2010 08:05 AM
IMPORTANTLY URGENT: Advise on the compatibility fix to open LV 7.1 VIs in 7.0 will be helpful.
Many thanks,
Ifeanyi
Many thanks,
Ifeanyi
‎10-07-2010 08:12 AM
You need to open the VI in version 7.1, then do a "Save for Previous Version" to save back to 7.0.
‎10-07-2010 08:20 AM - edited ‎10-07-2010 08:22 AM
Thanks Ravens Fan. I don't have a 7.1 at hand, as these are archived programs. 7.0 is the closest anyone around could find, thanks for the suggestion.
