Clock drift on a cRIO ... getting way more points than expected?
I discovered an odd issue today.  I have a really simple LV RT application that is running on a cRIO 9040.  It captures AI voltages at 20kHz.
I noticed that I was getting a lot more samples than I expected.  It seems like either the clock on my CRIO or my system clock is really inaccurate.  Or I am just doing something wrong.
I suspect it is the cRIO because when I sample some OPC tags, they match the count on my Windows clock.
Below is a screenshot of my code.  And I attached my code, too.
Can someone explain this to me?  I should be getting 20,000 points a second, but it looks like I am getting a bit more than that?
http://www.medicollector.com
(1,625 Views)
Hi j,
Which DAQ module do you use?
(1,600 Views)
It’s a NI 9232. Going to use it for some remote vibration measurements.
(1,575 Views)
Accepted by josborne
The 9232 is a DSA device. It can only sample at specific divisors of its internal master time base, 13.1072 MHz.
I am guessing that it is sampling at 20.48kSa/s. The formula is
(1,569 Views)
Oh wow that is totally it!  Thank you!
(1,557 Views)
Hi j,
Yes, reading the specs/datasheet often helps... 🙂
(1,526 Views)
Unsolicited advice: please take the Wait out of your Read Loop and wire the desired samples into the DAQmx Read VI.
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
(1,331 Views)
