06-05-2019 07:24 PM
Interesting read regarding VIMs in PPLs: Malleable VIs in Packed Project Libraries.
My situation:
Is this expected behaviour? The workaround in this case is simple, but I'm unsure why it previously worked and now fails. I'm glad the error message was at least suggestive of the problem though.
The malleable VI and a screenshot of an example caller are attached.
06-07-2019 07:51 PM
Hi cbutcher,
I think it has a linking issue because of upgrade and similar issue with below page. Could you check it?
06-08-2019 01:18 AM
Ueno-san,
Thank you for this information. I read the article that you linked to, but am not sure if or how it applies to the situation I described.
I didn't see a version mentioned in the article but note it was updated in May 2018 - should I read into this that you're suggesting changes to the linker in LabVIEW 2018 are responsible for modifications to the handling of VIMs?
My SubVI calls are all statically linked in this case, but perhaps you mean that malleable VIs behave in a similar way to dynamic linking? Without a more detailed understanding of the internal workings, I couldn't do more than guess at that.
Thank you again for the information, although it still doesn't really tell me if there is some intended change in behaviour or if this is a bug.
06-08-2019 02:58 PM
I'm not sure about your class VIs, malleable VIs relationship in PPL. Could you make very simple reproductive example project? I will try to check the behavior.
06-09-2019 06:34 AM
I can post an example later when I have a computer available but I think I've worked out at least why it can't be done now. Perhaps previously it was excluded but didn't trigger the error.
When the VIM is part of the library (I think the class is irrelevant in this case, but I haven't checked that), and has public access scope, LabVIEW should try to make it available to callers of the compiled PPL. However, I'd guess that actually this doesn't make much sense - what is a compiled inline VI without its caller?
Once I move the malleable VI out of the library, it no longer forms part of the API and so can be cleanly compiled into the library (class) VI(s) without concern that it might be needed with different datatype.
06-10-2019 01:34 AM
It can not be determined because it can not be reproduced, This issue may correspond to the rare case of the upgrade mentioned on the following page.
There is some Caveats and Recommendations for Packed Project Libraries in this Help page, and mentions about including classes like below.
If the error occurs after upgrading as recommended on this page, please attach the
reproductive project.
