Class library is locked, but shouldn't be
I've run into some particularly weird behavior of LabVIEW 2011 SP1:
  • I have a base class, "Scanner". Child classes will generally have a member VI called "Scan loop.vi", so Scanner has a member method "Scan loop template.vi". This template can be used to make creating a child class easier.
  • I created a child class, "MCL Fast Scanner". I copied the "Scanner : Scan loop template" member VI, and added it to "MCL Fast Scanner", renamed as "MCL Fast Scanner : Scan loop.vi".
  • Now, for some strange reason, when I open the project, the "MCL Fast Scanner.lvclass" library appears locked, with LabVIEW indicating that "this LabVIEW class is loaded in multiple application instances". I'm pretty sure it isn't (note: I'm note using any real-time targets).
  • I found a way to unlock the library: simply open "MCL Fast Scanner : Get scan loop.vi", which happens to contain a Static VI Reference to "MCL Fast Scanner : Scan loop.vi". Opening this VI mysteriously makes the library lock disappear.
I've tried to summarize this in the picture below:
So I'm not entirely sure what's causing this behavior:
  1. Either it's because I originally messed around with copying this template VI from the base class. This would seem similar to a post from a few years ago, mentioning an eerily similar issue. However, I afterwards tried re-creating "Scan loop.vi" from scratch, and that didn't solve anything.
  2. There's something strange going on with the Static VI Reference.
  3. I created the "MCL Fast Scanner" child class using the LVOOP Assistant; could that have botched something?
Feel free to contact me if the actual files are needed for further investigation.
Thanks!
Science & Wires — a blog on LabVIEW and scientific programming
http://scienceandwires.com
Message 1 of 9
(4,615 Views)
Could you please post an image of the code containing th static reference?
Curious,
Ben
Message 2 of 9
(4,596 Views)
Sure 🙂 It's nothing special:
Note that I've used similar code for years all over the place, but this is the first time I've encountered this issue.
Message 3 of 9
(4,592 Views)
Hello onnodb,
I do not have explanations for such a behaviour at the moment.
Perhaps you can post the actual project in order for me to reproduce the issue and see what is going on?
Thanks!
Cédric | NI Belgium
Message 4 of 9
(4,551 Views)
Hello Cédric,
Thanks for your reply! It's much appreciated.
Would it be possible to send a snapshot of the code by email? It's a relatively big project that's still under development for a scientific research group, so I'd rather not have the code publicly available at this point.
Onno
Message 5 of 9
(4,536 Views)
This behaviour is actually caused by the auto-populating folder feature. If you put that feature off, the library does not appear locked anymore.
The issue has been reported to the developpers and should be corrected in a further revision.
@ Onno: I just sum up here our discussion to make this post complete, nothing new for you.
Cédric | NI Belgium
Message 6 of 9
(4,508 Views)
Please post the CAR number so we can check for it being fixed.
Than kyou,
Ben
Message 7 of 9
(4,501 Views)
Hey,
Actually, there are more than one CAR related to the auto populating feature opened at the moment 🙂
Ealier in the development of his project, Onno ran into some corruption of his project (for reasons only him can give you). He thought he had resolved -most of- them. Thus, the locked library issue he still have at the moment is probably a consequence of a previous corruption. Because of that, I cannot give you a precise CAR reference, but for sure, the R&D is aware of some issue with the auto-populating folder. This one (CAR#347498) is probably intersting to follow though.
Cédric | NI Belgium
Message 8 of 9
(4,486 Views)
I just ran into this problem and thankfully, was able to fix it in my case. I'm using LabVIEW 2011 with classes and autopopulating folders.
1. I was able to open the class by itself and it wasn't locked.
2. When I opened the project, the class became locked.
3. After looking through the vis in the project I found one vi that was formerly part of the class but I had removed from the class.
4. The vi itself was set to be part of the class even though it shouldn't have been. I deleted the offending vi and the class was no longer locked. I'm sure you can also just save the vi instead of deleting it. However, I didn't try that approach because I didn't need the vi in this case.
Hope this helps!
Message 9 of 9
(4,264 Views)
