Choosing between two loops to execute
For example, let's say I created a VI with two loops...is there a function or way to allow only 1 of the loops to operate if a certain criteria is met?
So let's say if the number is greater than 10, loop 1 will execute but if the number is less than 10, loop 2 will execute.
I was thinking of something like a "if, else" kind of statement but I can't seem to find anything similiar to that in LabVIEW.
I didn't attach my VI because I haven't been able to figure out what functions to use yet. Any help would be greatly appreciated.
(1,332 Views)
This sounds like you need to use a case structure as in the picture below.
Run one case or the other.
     Rob
Message Edited by Robert Cole on 06-24-2009 04:45 PM
(1,324 Views)
Another way.
Now Using LabVIEW 2019SP1 and TestStand 2019
(1,321 Views)
I think you are approaching this from the wrong end.
Why not use a single loop containing a case structure with the two code alternatives? That would make much more sense. 😄
LabVIEW Champion. It all comes together in GCentral GCentral
What does "Engineering Redefined" mean??
(1,311 Views)
If the requirement is to run both loops simultanously use two case structures with in a loop
otherwise you could use them in two different states with a statemachine architecture
Sundar.
(1,293 Views)
