Chart monitoring Crash
Hi
I have a problem with Labview 8.5
The code I've attach is a part of my program; I use this loop to monitor the data acquired with DAQmx in other loop.
If I change the panel between Mic, Acc, Mic-Acc no problem.
After if I click on Slow, Labview crash.
Can you try my code to see if it's repetible the error?
Thanks a lot.
Michele
(2,621 Views)
(2,612 Views)
