Channel Wires and Sub-vi
Q: Is there a simpler way to make a sub vi executable when the sub-vi has a channel wire input?
Currently, when I try and execute a sub-vi stand-alone that has a chanel wire input, I get the error message "This VI contains an unwired channel terminal..." and the vi promptly stops.
My current work around is to put a diagram disable around the terminal plus put a channel wire in a hard coded false case. This is not a very good work-around since you have to remember to remove the diagram disable before releasing the code.
Another work around would be to create a wrapper vi for my sub-vi, but that just seems wrong. However, it is probably "safer" than the first option.
Am I missing something?
(I just started using LV2016 at my new job, previously was using 2013.)
Currently using LabVIEW 2022
(4,529 Views)
Accepted by topic author Frozen
Channel Wires need to be "fed".  You can pass a Channel into a sub-VI (I do it all the time, pass them out, as well), but you can't have a "naked" Reader or Writer, which means you cannot call a sub-VI with a Channel as an input or an output -- as they say in Pittsburgh, "This Vi Needs Wired".
For testing purposes, make a Dummy Top Level VI, put your sub-VI inside it, and Connect Those Channel Wires!
Bob "Channel" Schor
(4,500 Views)
That is too bad. I was looking forward to  using channel wires but it is just not  good fit for this particular project.
Well, there is always next time.
(4,465 Views)
