Changing x axis of mixed signal graph
I have this vi. I want to change the x axis of multiplot to length instead of time. But when I try to do to it shows a broken wire.
I am attaching the vi and the file I am reading in the program.
(2,536 Views)
Just a bad mixing and matching of array data, the (evil) dynamic data type, and clusters that sort of resemble a waveform, but aren't.
Use Build Waveform to get your integer array data into a waveform.  Avoid the Express VI's and the dyanmic datatype.
(2,533 Views)
I am still not able to do it! Smiley Sad
(2,511 Views)
is there any way to do that?
(2,493 Views)
You haven't tried.  You just posted the same VI.
Start by going and looking for the functions I mentioned.  Drop them on the block diagram.  Read the help for them.  Then yoiu should be able to figure out how to connect them.
(2,487 Views)
