Changing the scroll direction of an indicator
I have an indicator that I am using for posting a number of results and it has a scroll bar to allow the user to scroll through
the lines of the indicator.
One thing that I did notice is that when I write to this indicator, the first line written to it gets placed at the bottom of the indicator and each line there after inserted on top of the indicator.
Is there a property node or any easy way to change the order of how the indicator displays its data so that the first line
written remains at the top of the indicator and subsequent lines are displayed below previous written lines?
(2,147 Views)
Your description is missing all of the details. Is this a string indicator? How are you appending new data? If you are using the concatenate string function, you probably just need to swap the inputs.
(2,136 Views)
Accepted by topic author robojeff
an offshoot of this thread: http://forums.ni.com/t5/LabVIEW/Problems-clearing-a-local-variable-shift-register/td-p/2012006
You are getting the concatenation to be exactly what you tell LabVIEW.
(2,128 Views)
That was it.
thank you!
(2,120 Views)
