Changing the position values for a slider
Highlighted
When the slider is moved to middle position i.e. off the integer value is 1 and when it goes up the int value is 2. I need the integer value of the middle position to be 0 and up position to be 1 and down position to be 2. How to do that?
(129 Views)
Accepted by topic author Neha987
Right click on your slider and choose Properties.
Then in the Text Labels tab, unselect "Sequential Values" and give different values to the labels.
You can place them however you want.
GCentral
(100 Views)
thank you
(73 Views)
