05-25-2020 06:29 AM
Dear all,
I'm using a Mixed Signal Graph with two plot areas.
I would like to change the number of plots dynamically.
I tried to find the property node to set the number of plot displayed but without success (I found into this forum that there is a "legend: number of plots" proprety node but I don't find it)
When I right-click on the plot area on the front view, there is no option to add plots because it is grayed, I cannot change the number of plots shown...
Could you help me please? Best regards.
Sébastien
05-25-2020 07:13 AM - edited 05-25-2020 07:13 AM
You can hide plots with the property Plot.visible. If you want 2 plots displayed, you need to use a for loop like this :
The user can also right click on the plot legend and un-check "Visible"
Unfortunately it does not seem possible to choose the size of the legend like for a Chart with the property you mentioned "legend: number of plots".
You could also send to the graph only the data you want to display.
Yddet
05-25-2020 07:24 AM
Thank you for your answer.
This does not answer to the questions: why there is no possibility to add or plots by a right-click (not only change the visibility of the plots as you suggested) ans shown on my attached file?
It is grayed and we cannot play with this parameter.
Bests
