Changing frame and comment's background color
How do i change the color of frames?
2.
When i make a comment, the comment will be boxed. How do i change the color of the box and the box's background?
TQ
(5,843 Views)
Accepted by fmpfmpf
Show your tool palette and choose the pint brush tool.
Space bar toggles foreground/background
Ben
(5,834 Views)
1. What kind of frames do you mean?
If you mean a for or while-loop see below.
2. With the 'brush' tool you can select e a foreground and background color.
  • Select the tool (shift right click
  • Right click inside the comment
  • Toggle the spacebar to change between frame and background color
To change the color of the text use the text formatting tools in the toolbar.
Ton
My LabVIEW Ideas
(5,832 Views)
Guys how do i change the color of the comments that i create in my Block Diagram in Labview?
I want to set a specific color to the Letters and the Box of the comment. But I want to set this configuration for every subVI that I have used on my project. The whole porject has like 30 VIs with its comments (plenty of them) and I want to set this configuration for all of them and not doing it one by one
(4,815 Views)
