11-03-2010 02:50 PM
hello,
i have a few things that are disabled and or set to blink through their properity nodes,
only problem is that i seem to have no control over what colors they change to when they are disabled or blinking.
i have a green start button, when you press it, it starts to blink. but it blinks yellow and green! i want green and dark green..
i have an indicator that disables and greys when the "lock control" button is pressed. its against a dark grey background and when it greys out you can see the outline of the indicator (very ugly!!)
please help
11-03-2010 03:11 PM
11-03-2010 03:35 PM
When u use the blinker property its fixed to blink 1X a second. The colors are set by the controls property (but you probably already know this).
I prefer to blink the control myself using color constant box (its a constant so you can see the color (not number) on the block diagram. Take a look at the BD below for a stop button I blink 3X a second.
I keep a copy of the original colors so I can set it back to normal when my app is done. The have setting for 4 different values, true, false, t to f and f to t....
