Changing color of led using property node
Accepted by topic author Kmfood123
Well, you have an array of boundaries, so you could change some value to e.g. xx.01 or xx.99 to slightly shift the switch points.
Message 11 of 12
(1,183 Views)
@Kmfood123 wrote:
how do i do that?
As a fist step you also need to look at the help pages for "threshold array" and "round to -infinity". If you don't fully understand a function, you should not use it until you do.
This is a good way to learn something new, so take advantage of this opportunity!
Message 12 of 12
(1,167 Views)
