on my frontpanel i have a lot of LED's with the same look. So i decided
to create a strict control to avoid the adjusting of a new inserted LED.
Now i wants to implement the feature of setting a new color to the
states of all the LED controls.
I have created for every LED a reference for setting the colors inside a
loop.
But when i create the property for the color, i can't set it to write!
What's wrong or can't i do that if more than one userdefined control is
inserted?
My next question refers to the color property. It is an array with 4
elements, one for each state of the LED. Every entry contains a cluster
with two u32 int. I found out that the first number is the color. But
for what is the second nu
mber used?
with kind regards
Henrik
