Changing a buttons value via Property node does not activate the Event Structure "Button":Value Change Why and how to Remediate
I want to change an existing program to make it work automatically without user input ,thus I wanna activate a button using the program only to trigger the event structure
here a VI just as an example
(3,210 Views)
Accepted by 77maxmustermann
Hallo Max,
do you know the difference between the "Value" and the "Value (signaling)" property?
I recommend to read the help for each of them…
(3,193 Views)
Thanks I went and read them.
Now I know, and it worked thanks again.
(3,188 Views)
