05-25-2011 11:22 PM
Yes i tried to do the same in the posted VI.
05-25-2011 11:29 PM
You did not do that in the VI you posted. You have an EMPTY array. Not at all the same thing. Simply click on two visible elements and actually set their states. It becomes very obvious visually when you have an array with elements having their values set.
05-27-2011 03:56 AM
Dennis is right, you have connected two empty array to the write function of the DAQ driver. I've modified your VI which should work properly now. You have to try it.
Good luck!
05-30-2011 01:03 AM
Please send the VI in LV2009
05-30-2011 02:44 AM
Ops! Sorry. Here it is.
