Change the default color table in an intensity graph
Hi all
I'm using the intensity graph to display a grayscale image.
Now, I've got a little tired from the routine of placing the intensity graph-create a property node-connect it to my constant color table.
Is there a way to change the default color table so when I drop the intensity graph to the FP it will be with a different Z-scale?
Thanx!
(2,777 Views)
not sure if this is what your after
http://digital.ni.com/public.nsf/allkb/1ADFF221E27F5B5886256E6F007C7B58
hope it helps tho,
i did a search on this website for labview intensity graph  colour
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(2,774 Views)
This is not what I'm after.
What you suggested is another way to programmly change the color of the graph (which I didn't know about, thanx).
But what I'm looking for is a way to change the default configurations of the intensity graph, so when I drop it to the FP it'll be with a given color table without doing any programming at all.
Is it possible?
(2,761 Views)
