"Craig Graham" wrote:
>>Carlos Jorge Granadino wrote in message>news:38f9b018@newsgroups.ni.com...>>>>
Hi everybody,>>>> I'm getting crazy, because I'm looking for the way to change
the colour of>> the lines I want in the same string indicator.>> I'm doing
an application to control an instrument by serial port, and I'm>> concatenating
the lines that this instrument gives me, but there is some>> line that I
would want to change its colour, because there has been an>alarm,>> for instance.
And I only can change all the string.>> Is there any way to do this? I don't
know.>>I've looked into this before and not found a way. As far as I can
tell, the>only way is to have a series of string indicators, as ma
ny as you
want to>display lines, and programmatically scroll the whole thing- including
the>attributes- each time you want to add a line. You can manually do a>scrollbar
if necessary so you can scroll up and down. Tedious and>inefficient.>>An
alternative would be to go to an external application to do the logging,>via
ActiveX. This could be either in a separate window or in an ActiveX>container
on the front panel. Excel, Word or any other wordprocessor that's>ActiveX
could be used, but it'll involve quite a bit of groundwork. HTML>also could
be used, again in a standalone browser or embedded in an ActiveX>container-
you could also have pretty little icons next to lines if you want>things
to look particularly flash :)>>>>
Thank You Very Much for answering me, but I think I am able to highlight
the line I want using a Multiple Selection Box, with the atributtes Nodes
of the Multiople Selection Box is too much easier than using strings indicators.
Now, I have another question that I do
n't know how to solve. Is there any
array of numbers where I can see the lines that I have chosen?
This is now my new question I hope you will have a great idea.
