Change the color of part of a waveform plot based on button
Hi, thank you for the response. The problem is that it changes the color of the entire plot, and I had some issues with manipulating the DAQ Assistant signal, because i want to use a waveform chart to keep history of sensor measurement.
Message 11 of 25
(1,787 Views)
Hi Mehdi,
As I wrote before: instead of using InRangeAndCoerce you use the 3 buttons to determine the plot to be used.
It will not "change colors" as it works the same way the IRAC works right now!
Message 12 of 25
(1,773 Views)
This seems to be an AND operation:
if (according button is pressed AND signal index is in range) {
    return signal
else {
    return NaN
Greets, Dave
Message 13 of 25
(1,748 Views)
I tried not using the range and InRangeAndCoerce function, but it didn't work.
Message 14 of 25
(1,741 Views)
Hi Mehdi,
So what did you try?
What exactly "didn't work"?
Message 15 of 25
(1,736 Views)
I used the boolean state of buttons as condition instead of InRangeAndCoerce. I tried also to do the  AND operation:
    return signal
else {
    return NaN
Message 16 of 25
(1,750 Views)
    return signal
else {
    return NaN
It would always be best to attach the latest status of the VI so everyone can see how you implemented the logic and why it may/may not work.
Santhosh
Soliton Technologies
Message 17 of 25
(1,730 Views)
Please you find attached the latest vi.
Message 18 of 25
(1,717 Views)
Hi Mehdi,
what about this simple modification:
(You could even replace those stacked FOR loops now, but I left them intentionally.)
Message 19 of 25
(1,709 Views)
Hi, thank you for the response. So i had the same problem as i said before, this creates one curve with one color when i click on button ( when i click on another button it creates one another curve with one color) but not differents sections with differents colors.
Message 20 of 25
(1,679 Views)
