Change the Ring menu list at user interface
Hi. I have a ring menu where the user can choose from a list of lengths in feet. I would like to be able to put a switch for the user to choose between Feet and meters. So when meters is set and the program is run the ring menu will show lengths in meters instead of feet and vice versa. I have been playing with property nodes.
(2,830 Views)
You can change the list by wiring to the Strings[] property of the menu ring.
I've attached a sample vi that I think should answer your question. If not, then let me know.
Brian
(2,830 Views)
Hi. Thanks for your help. I actually solved this problem a little while after i posted the question. But your method is slightly different than mine and might work better. Thanks for the input!!
(2,830 Views)
