Hi Sonti,
the nice thing with the PolarPlot is: you can look into the subVI it comes with!
If you would do so you would find a sub-subVI, which is used to create the background image for the plot scales…
Your options:
- create a copy of the VIs supplied by NI and edit them to create the background image you would like to see
- just learn from NI and then create your VI from scratch! (You might also use a XY graph and put your own background image into the graph…)
