05-19-2010 08:52 PM
Hi, all.
Is it possible to change the Time and Date Dialog Box that appears in a Time and Date Control? There are several details I'd like to modify, for example, translate labels into Spanish, or remove the "Help" button.
Thank you very much,
Francisco
Solved! Go to Solution.
05-19-2010 11:20 PM
Check out this thread. http://forums.ni.com/ni/board/message?board.id=170&message.id=421557
The dialog box is a VI stored in the LabVIEW program directories. I wouldn't recommend making any changes to that as it would affect everything else you would do in LabVIEW. But if you make a copy of that, do not show the browse button on your control, but make a new similar button that calls the a copy of that VI that you have modified to your liking, and have your code handle the processing of that button such as writing the selected date/time to the control, I think you can make it behave similarly to the way the native LabVIEW control behaves.
05-20-2010 02:18 PM
