Change name of document sent to printer
If you print a document from a built application (using the print method or the print when completed feature of a VI) the document will be identified as a "LabVIEW document" in the printer queue.
Is there a way to customize this name to fit the name of your application/your document type?
(1,073 Views)
Sorry for the delay in getting back to you.
Please could you provide a little bit more information, how exactly are you printing the document and what is the document you're printing?
Are you using the Print.VI To Printer invoke node to do the printing?
Kind regards,
Joel G
National Instruments UK & Ireland
(1,030 Views)
All print methods seem to work the same way in this repsect; print on completed execution, print invoke nodes etc. Do any of them offercontrol of the name, or is there a general override?
(1,016 Views)
Right, I've had a look around and found that this functionality has been suggested in the past, but unfortunately, has not yet been added to labVIEW. All I can suggest at the moment is that you submit it as an idea in the labVIEW idea exchange and it may get included in the next version of labVIEW.
Good luck with your application.
Joel G
(1,007 Views)
