07-20-2020 09:19 AM
Good morning to everyone,
i try to explain my problem.
Is possible to change the executable (.exe) icon in Windows taskbar using LabVIEW code?
Is there any methods or trick to change the taskbar icon, using a different icon from the icon used in
the application builder?
Thank you.
07-20-2020 09:36 AM
There is a call to a system function that can change the applications icon.
https://lavag.org/topic/21339-changing-the-application-icon-at-run-time/
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
05-25-2022 06:34 PM
Hi, any chance anyone have the VI in that link? looks like it's not there anymore.
05-25-2022 07:58 PM
https://forums.ni.com/t5/LabVIEW/Changing-Icon-in-LabVIEW-Title-bar-of-a-vi/m-p/1480986#M560223
This seems to be the essential code. Needs some editing if you want to use this in 64-bit LabVIEW.
05-26-2022 08:23 AM
It's still there. Are you logged into your LAVA account? The post Rolfk provided is essentially the same thing as what is posted on LAVA.
05-26-2022 11:03 AM
Thanks for the help, I was not logged into LAVA. I used Rolfk link and that also worked for my application, thanks again!
