06-04-2009 01:22 PM
Hello everyone, I am currently a research chemical engineer at the University of North Dakota and I am having some problems with the write to measurement file function in labview. I have this program set up so it can take pressures of two tanks with a membrane in the middle to determine the permability of the membrane. The problem I am having is that the header for the columns in the file that was created by the write to measurement file are displaying untitled. I was hoping if somebody would be able to descride how to fix this problem. I attached a picture of the program.
Thank you
06-04-2009 02:36 PM
